Issues with waterpump and/or cooling
1,486
1,040
What a mess. And to think the description in the illustration calls it, "a protected area". Obviously not enough!
After you clean up that whole mess and do the repair, I'd consider some protective coating as added insurance. Maybe Deoxit Shield?
I would just put some raychem heat shrink over any exposed parts of the new ground strap and call it a day.
Good idea, but I can't tell given that mess if one could actually literally seal up the area with heat shrink. Maybe both ... but anyway, yeah wow ... not as protective as BMW though ...
Snowman
69
11
BMW 335 -07
In the future, use of an insulation tester( megohmeter) would save you tons of time.
The issue with that would be the risk of frying potential sensors or modules that happeneds to be connected to the same wire you were testing. Since I'm not 100% sure what was connected to it I didn't dare use one. Also how many people have access to an insulation tester :p?
Rcboosted2007
902
90
Parts unknown
07 335i
Correct. You would have definitely needed to isolate the fuse box and dme
