FS Injectors, 4bar, aic
pysical
471
108
2009 335xi E90
I have 6 index 12 injectors with less than 5k on them. I purchased from Oreily. They are BMW with the 261 part number. I bought new ones from ZNM hoping it would fix some issues and nothing changed.
600 shipped
4bar map sensor with harness. This did not work on my car and after research, certain cars wont work with the 4bar. I have a couple 4bar sensors that will go with it that I bought thinking they were bad.
100 shipped for harness and 3 sensors
Aic controller. This was used on PI but i upgraded to a newer one for use with FF. This one uses a boost reference from the manifold instead of tapping into dme wire. Older one but still does the same thing.
100 shipped
jahe82
Sadona135
Hi I'm new member , lurking for a while , I'm interested in the injectors ! Do you have them still ,all 6 , did you happen to put the caps back on the seals ??
pysical
471
108
2009 335xi E90
Yeah I have them. I put the caps on but they slide on and off real easy so don't think they are doing anything.
