Injector tool recommendation?
KevinC39
234
118
I'm looking to replace the fuel injectors and wanted injector tool recommendations. Thanks guys.
KevinC39
234
118
FCP sells one for the N55...
Yep that's where I was going to buy the injectors so I was going to just buy the tool from them too but figured I'd ask first incase people had one they preferred for whatever reason even though I assume they are all pretty much the same. I've never taken a DI injector out of anything before so I'm just trying to make sure everything goes as smooth as possible.
662
To remove the injectors you don´t need any tools. I changed them a couple of times just by pulling them with my hands.
You more probably will need tools for the new sealings which I bought directly from BMW.
derekgates
740
375
NW FL
derekgates.us
2011 335is
I agree, it was pretty easy to remove most of my injetors... but I worried about marring the bore.
The puller is simply a slide hammer... and if you can 3d print there should be some STLs out there.
KevinC39
234
118
Ok, after getting the wrong injectors swapped out for the correct ones, I got them installed this weekend and everything seems to be going well. It ended up not being too terrible of a job after all. The last two were a little annoying with all the wiring harness bundles, o2 sensor connections, and working around the hood shock but everything worked out.
Reactions: derekgates
derekgates
740
375
NW FL
derekgates.us
2011 335is
It certainly isn't a terrible job... just expensive. The big deal with the injector change is coding the car for the new flow pattern listed on each injector.
KevinC39
234
118
Yeah it wasn't too bad. I had just never done it before so I was a little hesitant going into it. I had the ProTool app to do the coding. It was really simple to use. I had used it before to code out the E-diff stuff.
