Injector coding
SlowE93
1,829
Just a plane ticket away !
E93
I already have the Carly app, jb4, MHD, and xHP. I need the simplest way to code my injectors. Ideas ? I have a friend that can come over n do it. I just like doing my own stuff.
The link I gave you points you to someone who can set you up with that stuff.
BMWE92_Harry
62
15
N54 E92
I've read that teh schawben or foxwell tool can code the injactors.
For INPA, you have to make sure you have window 7 or XP I believe, a lot of people run into issue with the install with the newer windows.
Edson
27
20
08 335i
I’m running it on windows 10 with a virtual machine with no problems, even coded my index 12 injectors smoothly. Just do windows xp compatability and you’ll be all set.
LMB335is
301
190
FOB FL
13 335is
BMW Standard Tools 2.12 (INPA, NCS Expert, Tool32, WinKFP) can be run on Window XP, 7, or 10 without the need for a VM. It only needs to be installed in Win 7 compatibility mode on Win 10 then can just be ran like a normal program. Literally takes 10-15 minutes to install with daten once everything's been downloaded to your desktop.
Edson
27
20
08 335i
I was using the e90 post file that had the virtual machine loaded up, that’s been the easiest one I’ve used this whole time, I kept having issues with the daten files not working
SlowE93
1,829
E93
You guys make it sound easy. Im VERY mechanically inclined.....but computers is a whole different ball game. Im sure if I had the program already installed I could code them, thst the part Im having trouble with. Sucks theres no simple way of coding them. Say via Carly app or something similar
LMB335is
301
190
FOB FL
13 335is
I guess if that's the only way you can get it work that's what you have to do. It's just a huge waste of space and processing. What is it, 50GB, 100GB? Standard install is 11GB with daten.
LMB335is
301
190
FOB FL
13 335is
I might be able to help you. Message me.
