Hybrid turbo base settings
Bmwfixerguy1
875
292
07 335i MT
Hey guys, so finally got my pure stage 2 high flows on. Inlets and outlets went back on as well.
I stayed with the jb4, (mhd low timing no spool) e50 and meth right now as well.
I searched around here and we don't have any info on base settings to get up and rolling (not over boosting)
Need to at least make sure she is all good be for I ask to get her all tuned :)
Trust me I would have posted a log but i can't particularly take one ;) it's 1-boost safety in a blink.
I set the duty bias to the settings in this link and still no luck http://www.n54tech.com/forums/showthread.php?t=33200
@Terry@BMS
@V8bait
Bmwfixerguy1
875
292
07 335i MT
12 was around 2700 just lowered it to 2k but it's wet. Not taking the car outta the garage lol
Bmwfixerguy1
875
292
07 335i MT
I just turned the FF rpm gain on, is that the one
Also Menu 10- 3000
Menu 11-3000
Menu 12 -1800
Took pic of FUD screen
Terry@BMS
Jan 23, 2017
464
380
The JB4 log would let me see your settings, in addition to what behavior the turbos are producing, as boost starts to build. So record a short log, even on a low map like map1, if needed.
A common mistake is not setting the "disable RPM FF gain" setting under FutureUseD bits.
Bmwfixerguy1
875
292
07 335i MT
Thanks Terry I definitely didn't disable that. I just did and haven't driven it yet. It's plain yuk outside but is supposed to dry up. When it does I can probably grab a log
Terry@BMS
Jan 23, 2017
464
380
It's one of the settings in the default hybrid settings page, details matter here. :)
Bmwfixerguy1
875
292
07 335i MT
Really? I read the one I have link like 10 time and just read it over again and still can't find where it says that. You always update the first post, is it deeper in the post and I missed it maybe?
Bmwfixerguy1
875
292
07 335i MT
I turned off the FF rpm gain
It seemed to get better until I tried to get on it
Here is the log of it happening
  • 2017-11-05 16_30_08.csv
Bmwfixerguy1
875
292
07 335i MT
Adding on to that, I feel like I for sure did one decent pull that stayed around 21psi
I looked at menus 10-12 and changed 12 back up because I felt I zeroed it by accident. Pulled a little and realized right away that the FF rpm gain turned off zeroed it so zeroed it back out. Pulled again and that is the log you see.
Arhoads335i
40
15
For stage 1 turbos should we also disable ff rpm gain? Or are they so similar to stock turbos it doesn't matter
dyezak
1,767
1,518
Plano TX
335is
Did you do some custom settings on your FF back when you were stock turbo? I'm no JB4 guru but I think your FF setting is too high.
FF Curve = Internal Mapping * duty bias/50 * FF/100
Based on how I'm reading Tony's documentation your FF setting of 148 is scaling everything up by 48%. I might be totally off base as I've never done this before but I'd reset the FF back to 100 as Tony advised in his hybrid setup thread you linked to in the original post.
Reactions: Bmwfixerguy1
Terry@BMS
Jan 23, 2017
464
380
FF is way above WGDC... Lower FF to 80.
FUA should be set to 0.
Meth safety mode should be set to 0 (default progressive safety, e.g. max safety)
Like I said, details matter. The hybrid default settings are default settings for a reason. ;)
Reactions: camberadam
Bmwfixerguy1
875
292
07 335i MT
I'll do all that for sure but am I following the instructions and settings on an old news thread, the link I have above is literally hybrid turbo settings and it says none of this I'd like to attach that to this thread for others on spoolstreet.. is there a different post?
Yes there was lots of other settings changed when I was stock turbo by trebila @dyezak do you know this thread or see where it is in the link? I usually follow directions and find info pretty good.
Thanks a lot guys, I hope this can help some others when the time comes
Terry@BMS
Jan 23, 2017
464
380
You linked the default settings in your first post?
Only difference is instead of 100 I said lower FF to 80, as I'm guessing that is where it will wind up. But, it has FUD there, has FUA there, has meth safety there, etc.
Bmwfixerguy1
875
292
07 335i MT
I'm sorry the way I read that was the duty bias in that screen shot not the rest of the page.. technically I used too much detail because it says "Larger turbos require special duty bias adjustments to get boost on target. Note default settings below as a starting point." lol ;)
Well all's well that ends well and I really appreciate the help on a Sunday! Houston we have lift off! 16lbs on the no spool low timing and it's the fastest my car has ever ever ever been! I think there is quite a bit more head room ;
