Hw 2.3 Fan Issue, coding?
samsonx
11
Hello everyone, I am working with Evo hw version 2.3. The fan doesn't seem to work properly. I didn't think it worked at all as it always stayed off until I performed a v850 clear. After, I notice if it was sitting in the bootloader state the fan would actually run constantly! I couldn't find a setting in in cafd for fan control for 0x63 NBT_HU2 but could be easily missed I think.. also didn't see anything in adjust block for fan or temperature..
Any ways to monitor fan or override it's behavior through tool32 or ssh?
Thanks!!
SK223
From my experience the fan won't turn on until it's reached a certain temperature, not sure what it is or how to check. On my bench setup I only hear the fan kick in briefly if the unit is on for a while. Seems like during v850 clear it just defaults the fan to 100% speed.
samsonx
11
Ok, thanks for confirming the behavior I'm seeing.. seems the threshold is around 60c on my unit, at least from what I see with sloginfo. Would be nice to change the config to much lower value for bench use! Cheers
