Datalog HPFP did it fail?
ididsomething
12
2008 bmw e90 335xi n54 MT
2008 n54 stage 2+ for a couple of years. It wouldn’t start after work one day. I got a log of it chugging along at wot.
I’m not very skilled at reading these charts if someone could give me their insight. Just looking for confirmation before I replace it or any advice.
ididsomething
12
Had the car 3 years, 2 years on stage 2+ fbo. I have not replaced either the lpfp or hpfp. I just drove it to get a log. It is parked until it’s fixed.
What does it say to you.
There's another issue, fuel pressures aren't good, but the fuel trim control is not working. Certainly keep it parked up until you solve it. Try take a log at idle with the Fuel Mode parameter logged.
Do you have any error codes? Anything dodgy installed like a JB4 or DPFix?
1,685
Lp behavior is super strange. Stft zeroed out. So are your corrections which is odd considering how lean you're running.
ididsomething
12
Here is a log between the failed start and the log I posted above. It was driving better less stumbling than the first posted log.
Sgop335
12
the lpfp gets old and the sock / filter screen clogged which cuts fuel flow. The problem ”could be” as simple as that esp. if it’s not been replaced. if Decided to replace lpfp, better to do w fuel pressure regulator. Error codes as mentioned above?
ididsomething
12
Over the course of a year I was getting two codes before the failed start. 29e0 and 29e1 which is mixture control 1 and 2. After failed start it just shows 29f2.
