Highest Mileage on their Hybrid Turbos
Krazi3azn
29
15
Canada
I know most of your warranties will be denied if you talk negatively about your turbos... So let’s focus on the positives. How much mileage are on your current hybrid turbos? Also please put your fuel and psi.
Example
“Pure Stage 2 DD - 10,000 KM+, 20psi running e40 + Meth”
N54QC
127
67
07 E90 335i
VTT Stage 2+ W/20T unclipped. About 20k miles. No issues so far.
Edit: Agree with Torgus comment so I will add. I am running approximately E50 with 20/80 - W/M at 25psi. As soon as I get my PI kit installed which I'm currently to busy to install, will be bumping it up to 28psi and hope they can take the abuse.
MattDeDom
2008 335xi
Pure stage 2s with 18k miles. It’s on a 93 tune so they’re only on 21psi. Pretty conservative, no issues.
Krazi3azn
29
15
Canada
peak psi and fuel should be mentioned.
the fact a warranty would be denied from posting online should be the 100% reason to never buy from that vendor.
OP, who denies warranty work if you make the failure public?
Good idea I’ll update it on the original post. MMP does and I believe another company that I don’t remember atm
dyezak
1,767
1,518
Plano TX
335is
Word is that MMP will deny your warranty if you speak publicly about failures. The interesting thing is that they are in TX, and that is illegal in TX. So if this is true, the affected party can get punitive damages against MMP from the state of TX up to the tort limit of $278,000. But it isn't likely that a 19y old kid who bought a $7000 335 and then put a set of MMP's on it would have a lawyer to be able to guide them through such a case.
zmon1300
181
114
Chicagoland
'10 335xi
Pure stg2 HiFlow @ 25-28psi Full E85, PR stg3+ LPFP w/ PI, MHD custom Full E85 tune by Wedgie. Been about a year and a half at around 550-600awhp. So about 12-15k miles. Pure turbos ftw.
Alex
18
Bay Area
2007 E92 335i MT
VTT stage 1's @23 psi, E60, 20k+ miles. Hasnt burned any oil whatsoever, ended up blowing a ringland on cyl4 so i pulled the motor and the turbos. These little things were beasts while the motor took it, got some VTT 2+ about to go in. Turbo's looked brand new, no play, no oil leaking, looks as new as my 2+'s. VTT ftw
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
MMP stage 3s 13k and counting. mileage includes everything from 1k engine break in no boost to 5k of 31-32psi on full e85. Currently on 20 psi pump gas for the winter.
edit: lmao these blew tf up at 17k tossed a turbine fin and coated downpipe in chocolate milkshake. fun times
1,152
1,203
Scottsdale, AZ
I know it "doesn't count" since I now work at VTT but I started as a regular customer. Old stage 2+'s, little over 30k, most of that 25-26 psi tapered to about 24 psi. When we do "project stock motor street car", we'll also do a show and tell of how they look once we pull them off and open them up.
Chris
