Help with wgdc
Rufus bmw
10
My boost dropping off from target from 4k RPM on. I can see wastegate % is relatively low. Do you guys typically increase wgdc base and adder to close the wasegates more and hold higher psi closer to target or adjust PID !?
Thanks
JBacon335
227
107
Toms River, NJ
I'd add 10% to the base and see how it holds. Load never hits target on that log but there's plenty of headroom
1,634
Do you guys typically increase wgdc base and adder to close the wasegates more and hold higher psi closer to target...?
Yes. This is what I do to get ~22-23 psi boost @ 4500 prior to taper (stock inlets) with WOT from stockers. WGDC is 99%...they haven’t blown yet after all these years!
Rufus bmw
10
What load target do you run for 23 psi ?
Do you also expend your wgdc y axis . I can see x axis is maf request and it needs to be scaled up which I did. What does the value on y axis represent ? Thanks
1,634
Here's my latest bin - for Flex Fuel. This is completely home-brewed based on tweaks and various adjustments over the years, including the latest throttle adjustments for an AT. Happy tuning!
  • Flex Fuel V1.3 Throttle 1.0_FF.bin
Reactions: GoldenGYPSY69
Rufus bmw
10
Thanks for your help. But what
Xdf are you using I tried to open some maps and they all seem to be scewed.
Rufus bmw
10
Mine is IJEOS.
Got it. I noticed your wgdc at 401 is value 58. Which I though was fully closed gates . Your adder for 401 is 35.63. how does adder help if your base value is already indicating fully closed wastegates .
Is x axis in wgdc base maf req or maf req wgdc log value ? I am seeing maf req wgdc as high as 520 in my logs. I am best to scale out the x axis into 500s?
Thanks again .
1,634
Sorry, I don’t recall. I haven’t looked at that part of the tune in quite some time.
JBacon335
227
107
Toms River, NJ
Thanks again .
100 would be completely closed in my understanding
