Hey guys, I keep getting a cylinder 6 misfire under WOT in 3rd gear around 6200-6800 RPM. Sometimes it doesn't happen but it usually will when i do a pull on the highway and near the redline on the tach. I've replaced all bank 1 injectors with brand new Index 12, and i replaced cylinder 6 with a new index 12 as well less than 50 miles ago. The car is FBO, no meth no ethanol. stock fuel pump, RB Inlets, new RB PCV valve, recent walnut blast and new NGK 95770 plugs gapped at .020". Can you guys look at some logs for me and see whats up?
https://datazap.me/u
EDIT: adaptions were reset prior to the log, running a Cobb AP, unistalled the Cobb and reinstalled the Cobb and custom flash from National Speed in Wilmington NC
