Having boost oscillations under WOT
DCT_JAY
66
16
2011 335is DCT
Not sure what could be causing this issue, i already checked everything for boost leaks, had one on the tmap sensor with a busted O ring and then replaced my stock diverter valves with a new Tial BOV and still have the issue. Spark plugs are needing a change and doing those when i get paid but i dont think thats whats causing my issue.
Any ideas ?
Seems like your wgdc is jumping around. Mods? What does your tuner say?
31125
DCT_JAY
66
16
2011 335is DCT
FBO (w inlets and outlets) with vrsf 3.5 exhaust , upgraded lpfp, about to put all new injector 12's in aswell. He suggested i had a boost leak witch i did and fixed ( Tmap sensor boost leak ) but im still having this oscillation
And your tuner still insists you have a leak?
1,634
So was the car running normally on the existing tune before this happened?
Asbjorn
856
607
European, based in China
Z4 N54 DCT
My wgdc also oscillates like this when I have a leak. We share the same tuner.
Could still be the tmap leaking. There might be an imperfection down there that cuts the o-ring. I have replaced my o-ring like 5 times, it would often come out broken until we cleaned it properly and used the right size ring. Eventually I sealed it up. Also sealed the bolts, as oil indicated there was a leak through the lower one. When my tmap leaked it was only 1-3psi and didn't show when smoke testing, but you could hear the air escaping when rocking it a bit.
DCT_JAY
66
16
2011 335is DCT
hard to tell i had a boost leak for a while but the bucking at low throttle and wot was kinda always there , just not this bad.
DCT_JAY
66
16
2011 335is DCT
exactly what happened to me bro ! , ill look at it again today and check. i also put threadlock and sealant over the bolts to ensure no leaks cause mine was at only 1 psi when we smoke tested ! imagine full boost
DCT_JAY
66
16
2011 335is DCT
quick update, took my car to BMW to have all of the injectors replaced because i suspected they were pretty bad.
good news is, it fixed most of my issue and actually made alot more boost and felt alot smoother even without the new plugs yet (was literally on my way to get them replaced and took these logs after driving 60 miles to let the car adapt to the injectors). Bad news is, i think from the previous issues the surge fucked up the thrust bearing in the front turbo and is now toast so..... i guess im moving to upgraded twins now.
