Functional description BMW ZF6HP transmissions
RayBan
154
155
www.rbttuning.com
Everything you probably ever wanted to know about the Z6HP transmission and their specific implementation in BMW vehicles.
Recommended read before starting to tweak on the TCU.
TOC:
- Brief description
- The Lepelletier planetary gear set
- 6HP26 torque converter w/wo torsional vibration damper
- Converter Lock up clutch
- Oil pump
- Shift elements
- Shift overlap control
- Parking lock (E/M Version)
- Overview of shift system
- Description of gears/powerflow
- Hydraulic circuit diagram
- Hydraulic and electronic control units
- Technical data 6HP19/26/32
  • bmw_zf6hp_functional_description.pdf
4,350
When it mentions 19/26/32, are they referring to just the first generation transmissions and any overlapping technology?
