F22 m235ix build
6inarow
18
Seattle, wa
435i
Been searching for the limits on the n55 m235i crankshaft, and my builder is saying the crank needs to be stronger for the power goals I have(800whp). The s55 crank is a different part number, but has anybody used it in the n55 for a high power build? The block has a block guard, forged rods and pistons, race bearings, yadda yadda. Wondering if my recipe is going to hold this power without changing the crank.
Thanks for the advice, and comments, trying to get a better picture of what these engines are capable of.
6inarow
18
Seattle, wa
435i
Have you seen this video? He's running 750whp on a stock engine m235i.
Very good video to watch, a lot of good information. I’m throwing nitrous at this engine, using a shuenk n55+ turbo on 93. It makes 480wheel, and then I’m building a port nitrous kit for a 2 stage setup. 100 first hit, second stage is another 100. The hit is going to be hard on the bottom end, even with a progressive controller. There are some who say the s55 crank fits, and those cranks hold tons of power. the bearings are the same from acl and king, N/S55.
Reactions: houtan
6inarow
18
Seattle, wa
435i
Cams arrived. CAT camshafts 278/272. Seeing if anybody runs them, if not, I’ll find out this spring time. Also running Ferrera springs and retainers, with a modest port job. Got ARP 11mm studs. Getting excited to get everything back from machining!!
Reactions: houtan
6inarow
18
Seattle, wa
435i
Looking around the shop I’ve noticed I’ve accumulated a bit of n55 parts. So I put some spare parts together and made a mock up engine! Bare block and pan, oil pickup, and cylinder head, and subframe!
All that to build to design a dipstick! I know, a lot of stuff for a dipstick, but I’m sick of not knowing the level of the oil. A few seasons on the track, and it’s really annoying to not be able to check oil on the fly.
I have an F22 m235i Xdrive. Location will probably be on the passenger side. I’ve looked all over for a point on the pan itself, but nothing looks like a good place. The is a place on the rear passenger side bedplate, that might be a better option, but I’ll get deeper as I get a mock up turbo and downpipe on.
I’ve seen two kits, BMW M4GTS. Requires coding out the electronic level sensor, but it’s replaced with a dipstick on the driver side, AND RWD only. The other has to be welded onto the pan, and it looks like a lot of work.
The subframe was sitting outside for over a year. I’ll cleaned it all up tomorrow, I’m tired.
CalvinNismo
165
244
I’ve got the Schricks installed on mine, she’s running, but not drivable yet. Standard head and valvetrain for me.
There are 2 dipsticks from BMW available, one that uses the normal S55 sump.
And one that uses the racing sump.
Both are for RWD setups like you’ve said.
There’s also this M18 kit.
Liking your build so far! I look forward to updates.
6inarow
18
Seattle, wa
435i
I was looking for install instructions, but couldn’t find any. Would like to know where those small parts attach.
But I got the motor all mocked up with the turbo and downpipe, and looks tight as all hell.
I got a couple pics, and I’m thinking the bedplate office near the rear of the engine is gonna be the ticket.
Tonight I’ll get the mock up torn down, and just leave the bedplate and engine arms, and maybe drill a hole!!
First pic is the two locations I wanna drill, the second is where it’s gotta come up through the bottom.
6inarow
18
Seattle, wa
435i
Got the mock up torn down to just the bedplate, oil pan, and engine arms on the subframe. Looks like I’m going to drill a pasageway on the bedplate. I don’t want to weld it, cause it’s the bedplate and I don’t want it to warp anywhere. I’m thinking a threaded fitting with an angle down to the sump. Seems like it will clear the oil level sensor, with some tweaking.
The second pic shows the oil pickup location, and the third is where the hole will be and the routing of the dipstick.
890
Comment/question unrelated to dipstick design - Hard to tell from that pic, but it looks like the front drive shaft would interfere with the subframe? But it looks like the engine mounts are all seated? Is that any optical illusion in the pic?
6inarow
18
Seattle, wa
435i
The axle shaft goes right in front of the control arm. Straight though. There isn’t much room for anything, but that axle fits snug under the car. They found a way to shove 10 pounds in a 5 pound sack for sure.
6inarow
18
Seattle, wa
435i
Got a small hole drilled, 1/4” NPT, and the fitting is gonna touch the rod, so I saw that the turbo oil drain line is the same size as this port, so I drill it out to 18mm, and it fit snug!! Looks factory, kinda… I’ll end up brazing a longer tube to make it to the top, and the interior piping was ordered yesterday and it’ll be here tomorrow.
Don’t have a pic yet, but I won’t have to braze a longer tube. I cut the nipple off, and a 1/4”npt tap worked like a charm. The tubing will still be used to get the dipstick to the bottom of the sump, but things are looking up.
6inarow
18
Seattle, wa
435i
Gave my idea to the builder and he is gonna get the rest of the dipstick figured out. In the meantime, I got a set of M&H racemasters in 26x8.5x17. The rears fit great, I’m gonna check the front tomorrow, but it’s hard to get the suspension loaded without an engine in the car.
Wheel specs are
Kosei K8R 17x8 et32. They weigh in at 16.5 pounds.
Since I had three sets(actually 4, I didn’t wanna get the forgestar wheels out, cause they are buried), I wanted to weigh the three setups and see how much I’m saving per wheel. I know my brake setup is saving a ton of weight, but I didn’t know about the wheels.
First pic is the stock 18x7.5 et45, with a 225/40/18
Second pic is a kosei K8R 17x8 et32 with a 245/45/17
Third is a pic of the same wheel but with other the racemasters on.
Amazing weight savings, especially between the street 245 and the racemasters.
The fourth and fifth pic are how the wheel and tire sit, loaded suspension.
Thanks for checking in, I’m just gonna keep chipping away, this place is great for documenting this work.
6inarow
18
Seattle, wa
435i
Bagged the idea of a dipstick, it’ll be another pipe dream for another day
I’m doing a port nitrous kit as well, and a lot of parts came.
Nitrous side:
10 pound tank with heater
-6AN nitrous feed line
Nitrous outlet solenoids and purge
Shark nozzles(only used parts)
Hand-bent stainless lines for fuel and nitrous
Pills for 75/150/225/300/375HP port shots
Fuel side:
1 gallon fuel cell
-6AN feed line
-4AN from solenoid to manifolds
-3AN from manifolds to nozzles
Bosch 044 pump
Low pressure safety switch
5/16 return line
Plan is for a 150 shot, still need some ideas for mounting everything in the trunk with no trunk linings.
6inarow
18
Seattle, wa
435i
Engine coming back this coming week, wanted to finish the nitrous before the engine shows up.
Fuel cell installed with a Bosch 044 fuel pump
Used an old Audi S5 coupe skid pan to mount my tank, fuel cell and brackets. Ran auxiliary fuel line same as low pressure fuel feed, nitrous goes through cabin and through firewall, under the wiring. Relay box and controller installed behind driver.
Need a suggestion for a WOT switch. It has a fuel pressure safety switch, nitrous pressure transducer and oil pressure switch. The WOT is the last safety to install. I would like to put a trigger switch on a button as a last safety. As in, I push the button, and the system is finally armed.
System uses a NOS mini2 progressive controller.
Thanks for checking in.
