I just installed the front Eibach front sway bar that is made to go with the Pro Kit Springs. Previously had M3 front and rear swaybars with M3 suspension and dinan rear toe links, ecs tuning rear trailing bar...then added Eibach springs and noticed more stability...however, geometry of M3 way bars was not made for Eibach lowered springs...so I installed this and WOW...what a difference. Car is more stable, no dipping on brakes or acceleration...almost totally flat in all driving scenarios.
If you get Eibach springs, I highly recommend getting the swaybar that is made for those springs. You won't regret it.
Pros: Cheap and more stability
Cons: a little heavier than stock M3 sway bar.
Recommended buy: YES.
Degree of difference in handling: Noticeble. Absorbs rough road noises and car is quieter, stays flatter in motion and braking, car feels more "one piece" than before.
Difficulty of install: I installed this morning before work from 6:40 am to 8 am. There was a minor glitch during install: the Eibach bushings do not match the stock M3 swaybar bushing holder that fastens onto the subframe...so you have to
1. use a dead blow hammer to force the oversized Eibach bushings into the M3 bushing housing which is smaller than the bushing themselves.
2. You have to be super flexible with legs and feet to hold and pry the bushing housing into position to thread the subframe bolts into the holes in order to screw on the nuts...or it's a two person job.
