E98
Milan
413
241
jebi se
your mom
Good luck with the fueling. If you can make it work more power to you but I have a feeling your HPFP will hate life
Reactions: veer90
1,630
I use it only for mixing with 93 octane since I can’t get E85 in my area any more. Never tried it straight up.
  • Love
Reactions: ninjacoupe
LamboLover
238
242
Everything
Less may well be more. Higher ethanol content gives a lower autoignition temperature that may not be offset by the latent heat of vaporisation. Combine with higher boost and/or leaner lambda because you are no longer knock limited and you could have preignition.
MoreBoost
361
143
In theory if you can burn a higher proportion of ethanol, you can generate more power from every pound of air in the cylinder.
But in reality I doubt you'll make much more power than E50. Not enough boost and rpms.
Reactions: veer90
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
DSM guys run 45+ psi on e85, if you want big power build the head and spin to the DME hard limit of 81xx RPM. If you want more, go syvecs. lol
Reactions: LoBoost
1,630
Where do you buy from? And does it get delivered?
Jake,
I buy 5 gallon cans of VP Racing Fuel E98 from K & G Speed Associates, 2343 West Chester Pike, Broomall, PA (behind Nicholas Smith Trains). ‭Call first to make sure they have it in stock (610) 359-1616‬. Last time I purchased it was about $40 cash ($8/gallon). You may also want the dispensing tube to avoid splashing: VP Racing Fuels 3044 Deluxe Filler Hose https://www.amazon.com/dp/B005G5R5LQ/ref=cm_sw_r_cp_api_i_ubfcBbJY02GJ9
I think VP would deliver the cans, but it’s very pricey.
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
Jake,
Thanks Jeff! May need to start doing this or ordering 50 gallon drums. I don't mind picking up 5 gallon cans though.
camberadam
257
106
Baltimore
Tasmin Green e92
Not sure if you ever heard of these guys, they used to have an e98 pump I would fill barrels from. From my understanding other stations complained & town gave them issues, but we're trying to open elsewhere. You may be able to setup a wholesale account or something.
https://www.facebook.com/omegafuels/
Sshec152
213
118
Aston pa
The exxon on 202&1 has e85 again, it actually tested as e87 yesterday. I have 2 55gal drums of sunoco e85r at home in case they have issues again
