E90 N54 ballast or bulbs? Thoughts? Pic inside...
Mightbaal
76
12
2008 335xi E90
Ok so I am not sure what is more common and how I can even check. I know i had an old Infinity that the ballast was part of the headlight that was shot and they wanted $2000 for a new headlight (they turned like the BMW with the steering wheel). Until I seen it was screwed on and ebay helped me lol. But with these are the ballasts more likely to go or the bulbs? How do I even test it?
Mightbaal
76
12
2008 335xi E90
OEM bulbs are expensive so it would be nice to test what is wrong alot of times it is the ballast on past cars that went bad. Dont want to throw hundreds at it on bulbs and waste money.
Itsbrokeagain
199
71
Strong Island
E70 X5d, E39 528iT, E46 325xi
The few times I had to get into these headlights, it was the ballast that took a dump. Kind of a pain to change as you have to pull the bumper and remove the headlight (ballast is on the side next to the radiator)
1,923
662
Usually the bulb will start giving off a more purple color as it starts to get closer to dying
