E90 headlight upgrades
Rcboosted2007
902
90
Parts unknown
07 335i
I found these
1,286
781
The biggest issue with aftermarket headlights is optics. The projectors on them are usually awful compared to own xenons. The other biggest issue is that I have yet to find any that at bi xenon. They all use the inner reflector for the high beam. If neither of those bug you, then it's just a matter of finding a set you like.the ones you posted look good, I'd run them if I could do a projector retrofit.
1,286
781
I seen some xenon kits for h1,h7 replacement bulbs.
The bulb typically isn't the problem, even cheap bulbs and ballasts work fine. It's when you pair them with an awful projector lens that output suffers. A new set of aftermarket lights with a bi xenon retrofit projector is the way to go as long as you can reseal them properly.
Itsbrokeagain
199
71
Strong Island
E70 X5d, E39 528iT, E46 325xi
polish your lenses and keep with 4200k bulbs. Those will be the brightest by far for output.
unfortunatley most of the aftermarket options for these cars suck, so OEM is usually the only route.
You could see if the LCI versions will bolt up, but they suffer from broken headlight adjusters quite often, or they pop off the lowbeam projector frequently. I see LCIs all over with at least one headlight pointed at the ground.
