E89 sdrive35i MOTIV flex fuel problems
Mon54ster
18
Hello guys. I've been having trouble with the MOTIV flex fuel kit install. Followed all the instructions but when I connect the flex fuel module to the dme harness i lose conection to the throttle body and it gets stuck. Flashed the flex fuel tune with mhd and reseted throttle adaptation but the problem persists. I left the the kit installed with the module disconnected from the harness and the car runs absolutely fine. No codes, but I don't get live data from the lpfp (pressure stays at 0) but the car runs fine, gets boost, etc. Any tips?
Mon54ster
18
Makes me wonder if you got a pin mixed up or the connectors are different on the E89?
Got an email from MOTIV and indeed, they told me I would have to repin some connections on the flex fuel module connector. It seems they differ for the n54 powered e89.
4,338
Do you have to change the wires or that connector? I was thinking instead you would use different wires on the subconnectors.
Tuppidsay
116
63
Seattle, WA
2008 535i
Having the same type of issue today installing on a 135i. I also lose my tmap as well as the throttle and accelerator pedal. Seems like the flex unit is shorting out the 5v reference from the dme. Do you remember what was changed by chance?
Thanks
Reactions: DreadedN54
