E82 Aero
Chill
17
BMW 1M
Did Anyone installed a splitter like APR or Hard Motorsport is offering for the E9x?
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
I have a splitter from OMGSplitters.com.
berns
175
266
'09 135i
I'm running an APR rear wing and am having APR build s splitter for the 1M bumper paired with my Vicrez front lip. Will update with photos when it's complete.
Reactions: Chill
Chill
17
BMW 1M
I ordered also the GT200 Wing @ max width. I'm just not sure if my cfk trunk can hold that Kind of load ^^
Relegate
2012 135i DCT
I have an Aeromotions wing, the OMG front splitter and side splitters, and Racelouvers.com hood extractors (vents). This winter I would like a better and wider front spitter that's chassis mounted. Would love some e82 Canards too. (pick is pre-side splitters)
31839
Dmak
74
41
09 bmw 135i
That hood vents must remove ton of heat! That location is 100% the best.
The e82 in this page is my car. I used their vents, works great. Took lot of time to research for the best location to put the vents on.
Reactions: Relegate
Relegate
2012 135i DCT
Would like a functional diffuser. No one makes one AFAIK
Yeah, I haven’t seen a “production” one. I’m still working on the engine rebuild money so once I got that sorted I’ll prob look at lsd and better suspension as I’m way over the limit of my street based set up.
Relegate
2012 135i DCT
The big issue is the oil temps. Need to go bigger and likely double cooler. That location for the vents was recommended by the mfg based on the radiator location. Wind tunnel tests on an A4 showed 42lbs of down force from a 20lbs of lift. The canards on the leading edge are really key to get the most out of the vents.
Reactions: Dmak
1,685
Same. None of the diffusers available integrate with the under body paneling to create a negative pressure space. Should be possible.
