E60 E8X E9X M3/M5 Cluster Retrofit
[email protected]
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
For those who are interested, ///M Cluster retrofiting is now available on my website... Send in your M3 or M5 cluster and have the VIN removed so that it can be paired to your car. We will send coding instructions if needed if you wish to have a local BMW programmer code it for you. You should purchase a cluster with lower mileage than your car
M3 clusters are a direct fit with the following cars WITHOUT exterior modification:
  • E90
  • E91
  • E92
  • E93
M3 clusters are a direct fit with the following cars WITH exterior modification(the cluster itself will need to be trimmed around the edges in order to fit, other than that its a plug n play cluster):
  • E81
  • E82
  • E87
  • E88
M5 clusters are a direct fit with the following cars WITHOUT exterior modification: (LCI 5 series must purcahse LCI M5 Cluser)
  • E60
  • E61
PLEASE NOTE: DCT SHIFT LIGHTS WILL NOT WORK WITH STANDARD AUTO CARS OR MANUAL
Click HERE to get started!
Andy
77
27
California
Can you make the ///M logo light up?
If so, could I send in my current M3 cluster for modification?
I wouldn't need any coding done.
