Dyno Results - Pure Stage 2 DD, VTT Double Barrel, E85, Wedge Tune
amik
14
15
Got a chance to dyno my 2007 E92 335i today after installing the VTT Shotgun Double Barrel last weekend. Made 634 whp and 609 ft-lbs. Had pretty major fuel pressure oscillations through the whole pull (similar to what's mentioned in another current thread) and some timing corrections toward the end of the run. Also had a cylinder 6 misfire right at the end of the second pull, so may need to adjust gaps or swap plugs now that I'm on full E85.
This is the first version of the E85 tune from Ken at Wedge, so I'm confident there's some opportunity for further optimization of the tune as well.
Overall I'm pleased. I've done every bit of mechanical work on this car myself so I was going to be pretty disappointed if it performed terribly, or worse, left parts on the dyno.
Drivetrain mods:
Wedge Tune via MHD
Pure Stage 2 DD Turbos
VTT Shotgun Double Barrel HPFP
Fuel It Stage 3 Bucketless LPFP
Precision Raceworks Coils w/ NGK 97506 @.022"
RB Turbo Silicone Inlets and Outlets (Factory Locations)
BMW DCI
VRSF 7" HD Intercooler
N54 Tuning DPs
ER Chargepipe w/ Turbosmart Diverter Valves
DIY Oil Cooler Retrofit
mFactory LSD
XHP Trans Flash
Datazap Log: https://datazap.me/u/amik/dyno-runs-wedge-e85-tune-v1?log=1&data=3-6-22
berns
175
265
'09 135i
Sick powerband. Would love to see what they do on lower boost levels like 16-20psi.
Oct 27, 2016
412
265
32
That's a nice curve man, the car must be a blast to drive. Congrats on the numbers, impressive stuff with that double barrel!
amik
14
15
Thanks, guys.
My 93 tune is around 21 psi and that actually seems like a sweet spot with the normal summer tires. It is a lot of fun to drive and the transmission will probably hold up better in that range too.
On E85 with 500ish ft-lbs at 3500 rpm it definitely feels quick, but has a little trouble keeping the tires hooked up in third. Nothing a set of 17” wheels and some drag radials can’t fix. It’s on 275/30R19 Pilot Sport 4S for daily driving now.
suspenceful
10 Second Club
Aug 1, 2017
552
575
75
2015 M3, 2008 135i, 2009 335i
Awesome! I'm running the same gap on my NGKs with the PR coils. I'm also going to try gapping them down to about 0.018".
amik
14
15
Did you dyno at 21psi on 93oct?
I did not. Maybe some time in the future.
Are you running the 97506 or the 95770?
Looking like pure turbos are the way to go
I’m happy with them so far. Very easy to deal with and the results have exceeded my expectations at this point. I struggled with whether to pick the DDs or the high flows, but I think the DDs have turned out to be a good match to my goal which was more about area under the torque curve than peak power.
Ztuck45
32
37
2010 335i
Very nice. I actually got a custom tune from Ken as well and my hpfp fluctuation is much better. It stays between 2200-2700psi at wot.
So far only pushed to 26psi but I’ll be on a dyno next weekend at 28psi hopefully.
Ace718
31
16
Las Vegas
'15 F10 550i
Looking forward to the video!
amik
14
15
Thanks. I’ll talk to Ken and mention the adjustments made to your tune and see if mine need the same.
buster84
240
91
335 bmw xdrive
Did you ever go back for another dyno?
