Does MHD support 3.5 bar in the OTS maps?
pysical
471
108
2009 335xi E90
Does anyone know if I can use a 3.5 bar TMAP sensor with the OTS maps? I know MHD has the option to select 3.5 or 4 bar but wasn't sure if that would actually modify the map to account for it or if it was for something else? I need to run lower boost when breaking in new engine and turbos so need to get something not as aggressive.
V8bait
505
785
Texas
MHD OTS will support the N20 sensor but you won't get any boost increase, the ceiling remains at 22psi unless you have a scaled map. There are no OTS maps with sensor scaling.
pysical
471
108
2009 335xi E90
Ok sweet. Currently was set to 26 psi on some old RB turbos. With these GC's and ported head I would say 20 psi is good.
pysical
471
108
2009 335xi E90
dont run upgraded turbos on OTS maps. they arent optimized for that.
Do you have a map I can use for breaking in the engine? I have a rebuilt engine and GC turbos with ported head. My current map probably won't do to well since its target is 26 lbs.
