I have a backlog of stuff to post, and I've been remiss as I've not wanted to do write-ups until projects are done. But somehow I have a ton of projects that are 80% finished, and the last 80% of the work is in the 20%. Anyway, there are a few threads on active cooling. I decided to build several active cooling EKPM3 setups, to include one for @barry@3DM's 3DM Motorsport track E90 build, @NoQuarter (we work on projects together from time to time), and of course my Z4.
First off, for reference, there are a few threads floating around on the subject: here on Spoolstreet EKP Active Cooling, Cooling the EKP, and here's one on Bimmerfest EKP Fuel Module Overheating - CPU Fan Install. And there are other solutions, wiring Hobbs switch, etc. I suspect one can even run multiple EPK's with a little bit of tomfoolery but not sure I've seen anyone figure that out.
An alternative is the EOSpeed BPM4 controller - which redesigned to support higher lift pump demands for the N54/N55. It's $650-750 and people seem to have generally good results with this unit. Definitely the buy it and run with it solution.
For the Z4, the EKP is in the trunk - plenty of room.
On to the DIY: basically my approach is a couple-fold:
First off there is an IC that is in harm's way, which is basically the PWM control. You can the Infineon BTN7960 Data Sheet which I placed in the N54 resource section of Spoolstreet. This until would benefit from a properly fitted and installed heat sink.
Second, add active cooling. In my case I decided to use a high end, Taiwanese-made fan, which mounts to the stock EKP case, which is then also drilled to flow air over the heat sink.
I have yet to determine how I want to wire the fan for power - I'll post when I hit that. In the meantime, minus any connectors for car hookup, here's what I'm using:
- Heatsink kit (easier just to buy a variety pack): https://www.amazon.com/gp/product/B078KB7V5J/
- Arctic Alumina Thermal Adhesive (great stuff, been using it since overclocking days): http://www.arcticsilver.com/arctic_alumina_thermal_adhesive.htm
- Noctua NF-A4x20 FLX fan (note they have a 10mm tall fan if space is an issue): https://noctua.at/en/nf-a4x20-flx/specification
