How the hell did he got so much hp without helix or port injection or the shotgun I dont get it? It's not possible to get the power on e40 even with stage 4 lpfp. Ask em what he has for sure. What fuel set up. Cause with e40 you can only boost 22 to 24 maybe just maybe psi and it's not 600 it will be 550 whp we did itSo I was trolling around FB marketplace and ran into a e90 with DAW stg 2+. I'm going to reach out to the guy and get his opinion on how the stg 2+'s have held up.
What was interesting it he dropped his dyno chart in the for sale ad.
His ad says he has this for support:
Dynamic Autowerx Stage 2+ turbos
Vrsf stainless steel relocated inlets
Vrsf aluminum outlets
Vrsf 7in Intercooler
Vrsf catless downpipes
Chargepipe / bov with tial spring
Revshift 80a motor mounts
Jb4 Bluetooth with mhd e85 BEF
Xhp stage 3 transmission flash
3.5 map sensor
M18 performance cast aluminum valve cover
Stage 3.5 dual fuel pump setup (primary walbro 450 with secondary walbro 525 activated by hobb switch on chargepipe)
That being said, his license plate is "30 PSI" so......these kind of numbers may have a short life span if they are true.
It is because it is a virtual dyno, not a real dyno sheet.How the hell did he got so much hp without helix or port injection or the shotgun I dont get it? It's not possible to get the power on e40 even with stage 4 lpfp. Ask em what he has for sure. What fuel set up. Cause with e40 you can only boost 22 to 24 maybe just maybe psi and it's not 600 it will be 550 whp we did it
Torgus, you and I are not friends by any stretch of the imagination, but you have more brain power in your toenail clippings than Jake Ulch. I'm surprised he can spell VTT right. If you saw some of the things he emailed Tony...
The valve cover or valve cover gasket needed to be replaced, or just left over oil residue from oil turbosWhat is the big cloud of smoke when you came to a stop (@2:00)?
