Change terminal 30g shut-off time in CAS?
Nisse Järnet
56
59
BMW E30 turbo 4wd
Hi!
Anyone know if its possible to change the CAS controlled terminal 30g timer from 30min to say 10-15min?
Hotter
94
Would be interested too, but I think its not possible. When battery is low it shuts terminal 30g in 10mins instead of 30min - I have observed this feature with my old battery.
Anything is possible if you find the parameter to set but why would you need to, BMW must it set it for a reason.
You could always ask Bimmergeeks the maker of Protools to see if they'll help out.
Hotter
94
Well it would be useful if car would go to sleep faster, less battery drainage. When its not sleeping it consumes ~1-5A.
Reactions: turbohugh
ok
Spoke to the BMW whisperer and he said no there is something like 6 stages of sleep, cant exactly remember the exact numbers but it goes something like this
30s
1min
16min
30min
1hr
6 hrs
Cant remember the exact numbers but you get the gist.
Or if your running a lightweight race battery keep it on a trickle charger or any type of battery should be kept on one that's not used for extended periods of time.
Nisse Järnet
56
59
BMW E30 turbo 4wd
Thanks guys, something around 16 min would be good enough for my application, I'll try to make it happen with NCS expert :)
(It's a S55 singel turbo swapped E82 with a bit of modifications to the electrical system)
you cant change it I was told thats just what is in the car now.
Our cars have 6 stages of sleep.
Have a go and see what you can come up with, if you trying to combine the f series can bus with the e series can bus is the most likely culprit thats keeping your car alive and not letting it go to sleep. Ive seen a faulty flickering led keep the car alive for hrs.
Nisse Järnet
56
59
BMW E30 turbo 4wd
Oh ok hmm, im pretty new to coding but ill try :)
No im running a standalone ECU for the engine but trying to use as much of the cars original modules/functions as possible.
It works like it is now, but im using the 30g for some things that need to stay alive a bit after engine shutdown, but 30min is unessecery.
Reactions: martymil
Evgeni
BMW 325d Lci
In CAS search for KL30G_TIMEOUT there are four values.
wert_01-30min
wert_02-60 min
wert_03-45min
wert_04-20min
Mine was wert_03 - 45 min and i code to wert_04 - 20 min. It is very useful for short trips. With NCS Dummy i think you can add new value and make it 10 or 15 min but I haven't tried.
