carbon fiber parts
Nov 3, 2016
103
41
Atlanta, GA
09 6MT 335i Single Turbo
They fit like all other carbon fiber does- "ok". Expect any carbon piece to need a little massage. I put a vorsteiner on an F10 and i expected for the $$$$$ for it to fit like a glove...... which it didnt.
its a molded in bump. not an anomaly
New.
250 sounds good? gonna have to package the hell out of it to keep it from being damaged
thanks for the response. I'm currently debating between this and a quad diffuser.
So these disc backing plates just attempt to catch a little bit of the air coming out of the wheel well brake duct hole? How much gap is there between the opening on this backing plate and the wheel well duct? I assume because the wheel is articulating, that it isn't matched up a good part of the time?
Alex@abrhouston
Oct 25, 2016
146
112
Houston, Texas
www.abrhouston.com
They don't attempt- they *DO*. Specifically they are designed to be used with brake hose routed to either the brake ducts in the bumper, or the front bumper to draw air. They will draw huge amounts while driving down the road from air pressure, and they fill the back of the hub/rotor area with air. Think of these filling the entire back of the hat of the rotor with air- pushing them out of the vents of the rotor itsself.
If only the brake hosing wasn't so hack job looking. I'm working up a custom trans cooler, and custom brake ducting is on the list of things to do.
