Can't get above 20 psi
keninger
66
12
335i E92 N54
Running my own tune with a N20 sensor with stock turbos and can't get above 20 psi. My dme is targeting a maximum of 20 psi even though my highest load is 212
Here is a log:
Datazap Link
What could limit the target boost?
keninger
66
12
335i E92 N54
You need to properly scale the map sensor, load targets, and associated maps accordingly. The mhd check box doesn't fully do this. 212 load you're seeing will be much more than 20psi.
Thank you I am aware that I will be seeing higher than 20 psi target. I forgot to increase boost ceiling and I though I have double checked that. That's why I was running around in circles trying to figure out what could limit it. I have kept the scaling stock and used the MHD check box for now.
