Can I get opinions on a log of mine?
iminhell1
419
207
I'm looking at the pressures (boost, lpfp and hpfp), none of them seem to make any sense to me during the timing pull range.
No codes.
Just need a place to start looking.
  • 2018-07-01 23_11_20 IJE0S IJE0S 200load 3bar scaling add timing.bin.csv
iminhell1
419
207
I think I found a problem in the tune. I'll have to log tomorrow and make sure.
I have Mboost option but i didn't change the boost ceiling. I can't find anything saying I'm supposed to and the only thing I di find is about changing it makes the car either not run or shift weird. bus in some old tunes I have it is raised. And I find a few mentions of others raising it.
I'm coming no where close to target load or boost, basically neutered at about 22psi. This makes sense I guess.
1,628
This sounds very possible to me. I haven’t looked carefully at my tunes / TunerPro in about a year so I’m a bit rusty. But I do recall varying boost ceiling to allow boost to go higher than 22psi in stock turbos. I posted several of my bins as *.txt files a while ago on here and Bummerboost if you want to take a look. Google search.
