Ad: BPM4 (LPFP) Fuel Pump Control Module Released
I didn't take any logs of the lpfp controler but its working its but off perfectly
Ambient temp 104f +
https://datazap.me/u/martymil/log-1545891436?log=0&data=2-3-7-14-15-21-23&solo=2
Is this like the Adaptronic unit from VTT with less functionality?
No, one is a fuel controller(goes in the trunk) and one is an engine management(goes under the hood). You could use them together if you wanted. The adaptronic controls PI injectors but not the fuel pump in the back(afaik).
scrllock
267
153
2011 335xi
For the OEM pump connection option, I assume that means if you're going with say the fuel-it 650hp option (just adding a 450 to the existing LPFP)? For a stage 3 (2x 450s) that option isn't needed?
EOSpeed
109
158
Chicago, IL
With the OEM connector option, we provide you with a BMW OEM top hat connector for 1 of your pumps when using the stock tophat. With this option there is no cutting or splicing of your factory wires to get the connection to the primary pump.
matreyia
1,780
711
335i e93
I went to your site to order but got super confused. Here is what I have on my car and I need to know exactly what to order:
1. Stage 3 Precision Raceworks LPFP with hobbs switch
This set up is comprised of two 450 pumps connected to the engine via wire into the charge pipe hobbs switch.
I just need to know what to order and what options to choose so I am not missing things or have things left over after install. I am assuming the install will be plug and play with no fuss. Take out old Stage 3 battery wiring to the top hat, and replace with your wiring setup. Hope it comes with instructions.
There are options that could or could not be necessary and not clearly explained. For example, there is an option for "OEM PUMP CONECTOR FOR ONE PUMP" which is confusing.... Do I need this if I have two pumps that are 450 warlbro? And do I need a top hat? I mean, my car already has everything installed from precision raceworks and it would be bizarre to require a top hat purchase.
Thanks for your assistance.
VT
EOSpeed
109
158
Chicago, IL
VT
So for that system you would select N54, then 2 pump and then you have the option to get the OEM connector or not. If you do not want the oem connector you will have to cut and splice into your original connector for the primary pump. The second pump wires will come with ring terminals so you can attach them to the screws in your top hat. We recommend changing out the screws they provide with either copper or Brass screws, since they have much less resistance than the screws that are provided. We use all 10ga wiring in our system, so their screw becomes the weak point and can cause the top hat to melt, losing the connection. We will be releasing the billet top hat soon with proper connector that will solve this issue.
