I think I finally got my wgdc base figured out. I don't have n20 with m boost I think max target should hit 21.9 psi . I am finding that my boost target never hits 21.9 even by raising load to 220 or higher. Is there a way to push it to the limit of own map?
I mean I can push it with wgdc base but if overshoot target boost limit I am getting throttle closures.
I know my timing is somewhat mild , the goal was to get wgdc base dialed in for now, but that shouldn't affect boost target .
So far I only see one boost offset table I think it might be it since it's only set at 93% which sort of explains why boost target never hits 21.9
Pull in 3rd
Pull in 3rd
