BMW 335d diff
abal97
Bmw 335I N54
Hello guys i wanted to know if anyone has tried this and what do i need to do, kinda lost here.
How can i get a 335d diff lsd? What do i need? Could i use my 1k hp axles and same driveshaft?
scrllock
267
153
2011 335xi
Wavetrac makes an aftermarket rear diff for the 335d. I *think* most 335d diffs are welded, though saw mention of very early 335d's being bolted (03/2007 and before).
Given that, you'd probably need to have your ring and pinion machined, plus the usual new hardware (gaskets, driveshaft/axle seals, etc.). You'd need to find a competent shop to take care of the ring and pinion, as well as make sure your bearing clearances are properly shimmed on the new diff. Then it's just a matter of coding off your ediff with protools or ncs. Don't know why you'd need to use different axles or driveshafts if they fit your OEM diff. Hope that helps, good luck!
abal97
Bmw 335I N54
i hvae a 08 335i 6mt trying to get that diff as it has final lomger gear ratio
LMB335is
301
190
FOB FL
13 335is
The easiest thing to do would just buy a complete pumpkin from MFactory. Pretty sure they cover the 335d with a 2.81 complete pumpkin.
