Better N54 oil filtration
11427854445 is the part number for the GTS M4 oil filter. This fits the N54 and has superior filtration and flow (different material)
https://www.fcpeuro.com/products/bmw-set-oil-filter-element-11427854445
odesh
61
40
Seems interesting. I believe it will fit just fine on N54, but kinda weird if the better flow and better filtration are in the same package. Normal person would think that better filtration would effect flow in negative way. Let us know, when you know better!
CalvinNismo
167
246
The S55 filter has already been mentioned before in the below thread from a while back. There’s some other good stuff in that thread too. I have run S55 filters the past couple of oil changes, there’s an M logo on the filter, does anymore need to be said?
Having both side by side though, they don’t look different really, I’ll dig out a photo.
Reactions: SlimE92 and wheela
pbondar
565
311
Allegedly the Mahle n54 stock filter is a better performer than the Mann…but that was based on a YouTube test…so (at the moment) I’d like to see the qualitative or quantitative analysis…🤔👌
899
Thanks for linking that thread. Not much talk of filters there, but a ton of super cool info, I learned a lot!
CalvinNismo
167
246
No worries and yeah, not much information on the oil filter itself. But this was the first thread I had stumbled across that mentioned the S55 filter and its alleged potential benefits.
I fitted a S55 (F8X M3/M4) oil filter, these are presumably high flowed version of the standard N54/N55 filter. It’s also used on the M4 GT4 race car.
AzNdevil
605
291
Hong Kong
M for money...but i think its not easy for common people to test flow levels/filtration of an engine oil filter.....
