800 whp: VTT GC's
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
After all the manifold testing we started thinking about turning things up. Left the car on the dyno today, and did a few more runs for fun. With some input from Ken@Wedgeperformance, we tweaked Justin's tune; upped the boost a little bit, added one degree of timing up to 6K. Voila 804WHP/741WTQ DI only. We knew the turbos had it in them. Great to see it fulfilled!
Car Details:
2008 E90 6MT
Open Deck, Forged Rods / Piston
Ported head / Stock valve train
EOS V1 manifold
VTT GC Turbos
VTT Inlets / Charge pipe
VTT DCI
VTT Double Barrel Shotgun DI ONLY (PI is not even installed on the car)
Custom LPFP Consisting of VTT Bucketless in-tank feed pump, Triple Walbro LPFP with Radium Surge Tank
BMS Downpipes
AD-e Intercooler
Custom PCV System
AEM AQ-1 Data logging system
Tuning by V8Bait with some tweaks by Ken @ Wedgeperformance
100% E85
Logs here:
AEM to show true boost: http://www.datazap.me/u/vargasturbotech/vtt-gc-804whp?log=1&data=4-5
MHD for fuel etc: http://www.datazap.me/u/vargasturbotech/vtt-gc-804whp?log=0&data=3-24&zoom=33-82
1,152
1,202
Scottsdale, AZ
Do you guys think DI and the ported head played a big part of being able to hit 800whp?
Well we hit 777 DI only without the ported head; so it was worth a little anyway just based on that. DI in general does help. Not sure how these numbers would compare to a standard hpfp and a bunch of PI if we kept the boost and timing the same; I'd GUESS that you'd have to run it a little richer but who knows until you actually test. DI is a beautiful thing when operating within design parameters.
Reaper0995
69
20
These are great numbers! Do you know what cfm your heads were able to flow after porting? Stock intake manifold?
Reactions: RSTECH
