6266 Tasman Green e92 V2.0
camberadam
257
106
Baltimore
Tasmin Green e92
So I guess I’m finishing up my build V2.0...
Way back when:
http://www.e90post.com/forums/showthread.php?t=857028
I was FBO (pre-inlets) when I saw Terry list his FFTEC kit for sale. GC's weren’t around & I wasn’t crazy about the associated heat of a top mount, so I took the bottom mount ST plunge. I collected parts over a year or so, let the platform evolve & jumped in this winter. Goal is 7XX hp & the car has around 95k on it at this point. Project snowballed a little, but when I build something I want it dependable as possible & to look like it could have come from the factory that way. I’m too OCD to use the red/blue big block Chevy fittings. If there was a serviceable item that was more accessible during install, I updated it. I cleaned or degreased or painted pretty much anything along the way.
New stuff list:
-fftec bottom mount
-PTE 6266 bb Gen 2
-Tial WG
-AuBeast fittings
-new index 12 injectors
-new coils
-NGKs (97506)
-ADV o2 sensors
-3.5 Tmap & BMS harness
-Mac valve
-added OFH w/ outlets converted to 10an
-Setrab 34 row oil cooler
-new waterpump & thermostat
-new tensioner, pulleys & belt
-034 Motorsports motor mounts
-UUC trans mounts
-upgraded alum guibo
-BMS shift rod
-Spec 3+ clutch, oem TOB & bronze pivot
-Mfactory FW
-new rear main seal
-modified BMS OCC
-CSF radiator
-Fuel-it Stage 3 bucket
-Fuel-it 6an feed line tank to PI
-Fuel-it ethanol sensor
-walnut blasted
-Sharps manifold w/ PI
-Bosch EV 14 550cc injectors
-BMS PI controller
-oem 335d snorkel
-all new T-bolts
-all nylon covered stainless braided hoses (oil & boost ref)
-Aeroquip hose (vaccum)
-matching AN fittings
What’s left:
1. wiring connections @ DME
2. connect battery terminal
3. fuel/oil/coolant leak check
4. reinstall exhaust
5. Y the DP from single outlet to dual 2.5“
6. load software
7. START THE CAR
8. air leak check
Once I get to the tuning stage I’ll determine if/when I need an ADE intercooler. Also, I'm price shopping for M3 diff parts & pieces.
I’ll go thru all my pics & get them up as I get time this weekend hopefully.
4,348
When you say housing converted to -10, do you mean a blockoff/delete plate? Do you run a oil tstat?
camberadam
257
106
Baltimore
Tasmin Green e92
Nope, I tapped the oem holes out of the bottom to 3/8" NPT & ran lines like factory to a Setrab cooler. The car didn't have a cooler so this is still an upgrade & will give me time to prioritize/figure out which thermostat setup I want.
camberadam
257
106
Baltimore
Tasmin Green e92
So here's where I'm at after the weekend - starting to look like something again...
Current status - OEMish:
Engine Cover off:
Fuel injector spacer & Fuel-it plumbed:
Breather hose mounted (old racers trick):
Fittings on point:
OCC retapped:
Oil cooler mounted:
Oil cooler brackets:
Wheel liner venting:
Header wrapped:
Turbo mounted:
4,348
Interesting to see how yours is done after looking at mine. Does your water pipe go below the compressor? And it looks like the water pump is going to be in the way of the compressor inlet? These kits are very tight, mine has clearances but not much.
camberadam
257
106
Baltimore
Tasmin Green e92
1. Water pipe is the black circle @ the 8 oclock position.
2. Water pump sits in front of compressor filter. My plan was to have the filter where vac canisters were, but I would have choked the turbo w/ the piping that could fit. New plan is to make a "turn down" like tip to direct air out of the 335d snorkel toward the filter.
Other than that, the worst has been the middle manifold nuts; they were brutal.
4,348
Have you fitted the water pump and the filter though? Can't really tell on yours, but the water pump on mine comes very close to the silicone coupler for the intake pipe, in fact, it bumps up against the pump a bit.
camberadam
257
106
Baltimore
Tasmin Green e92
Remember what I said when you were concerned how the snorkel duct fit lol... Yes, I left the subframe in... :cool:
I finished DME wiring last night. Leak checking & possibly loading software tonight.
4,348
Yes, I'm mega anal. I try to let things be though. Currently my obsession is converting my wg lines to AN.
4,348
Well I already bought all my fittings and that was largely based on shipping times(Next day/2 day). The biggest cost was the PTFE SS lines with 4 AN fittings installed. A couple AN banjo fittings, NPT to AN fittings, AN distribution block and lines and we'll see what happens.
camberadam
257
106
Baltimore
Tasmin Green e92
My old exhaust cleaned up pretty well. It's ready to go back under; then finish mocking up the DP.
50k+ miles (CPE w/ resonators added):
4,348
Your coolant reservoir line is so much cleaner than mine, I need to do that
Where are you routing this to? That is the flapper valve hose that normally goes to the rear inlet, right? I was trying to explore some kind of vacuum setup.
camberadam
257
106
Baltimore
Tasmin Green e92
Challenge accepted... kit was originally setup for single 3" exhaust. My buddy Eric @ Killer Koncepts helped me out w/ some tig magic.
1. fftec downpipe
2. fftec dumptube
3. flange I drew up & had waterjet
Meet Frankenstein.
4. recycled 3" supra downpipe section
5. vibrant J bend & o2 bung
Metal finishing & wrapping tonight up next.
Reactions: 08_335i
camberadam
257
106
Baltimore
Tasmin Green e92
Correct. The turbo filter has an alum plate w/ a nipple/barb on the top. There is another preformed elbow just above water pump. I went to the parts store & asked to see their preformed heater hose selection in the back. Just measured different ones till I found diamters/bends I liked.
After it gets up & running I'll probably add a 2nd OCC in area behind the headlight. The 1st mount I made looked like garbage & I wasn't able to come up w/ one I liked so I moved on to other things. Will mess w/ it when I make the snorkel turndown.
4,348
1. fftec downpipe
2. fftec dumptube
Meet Frankenstein.
Single 3" or 3.5"? I'm trying to convert to single 3.5"
camberadam
257
106
Baltimore
Tasmin Green e92
UPDATE:
1. Tuning has begun!
2. New 3.15 M3 diff arrived :cool:
3. Currently sourcing new bushings; then mock up for 1pc driveshaft conversion
