335 manual thinks it’s in neutral
coulda
Hey I’m having an issue with my car where it’s causing it to drive extremely weird from how it usually drives. I’m pretty sure it has something to do with it thinking it’s in neutral instead of it being in gear. You can see on one of my logs from a couple weeks ago it shows that it’s in 6th gear, now it doesn’t show anything at all. My turbo doesn’t spool like it used to and my throttle is extra sensitive. Also instead of the car burbling going into decel (letting off the gas) it just starts engine braking right away. It’s a 335is with a factory manual I’m not sure if there’s a sensor that’s messed up but there is no codes on mhd.
Try logging vehicle speed. Also upload logs, screenshots are worthless.
Read the complete car for codes, not just the DME.
Has the car been coded with any of those trash tools lke Carly?
