While on track, engine was running strong, but then after coming off throttle and going back to full, there was zero boost available.
30FF was thrown. I reset codes and drove around the paddock, but regardless of what I did, zero (and I mean zero) boost is created.
Charge pipes do not appear to have leaks, and I've not found any obvious vacuum leaks. Prior to this, I could hear the turbos spinning even by just revving, but that no longer occurs.
Turbochargers are stock. I could see one turbo going bad, but both at the same time seems incredibly unlikely. What should I check?
Thanks!
-Joe
Thanks!
-Joe
