A
Datalog 3/4/2025
allenj125
I am having an issue when I get above 10psi of Boost. The engine starts to shake badly. I am new to reading these graphs. Can anyone see an issue? 2007 BMW 335xi. I kept frying MOSFETS until I upgraded to the msd81 dme.
ktb_e92
60
29
Indiana
2007 335i MT6
What trouble codes are being tripped when it breaks up over 10psi of boost around 4500rpm?
Sometimes a failing MSD80 can take out one or multiple ignition coils & fuel injectors which will either show up right away or when applying boost. Another reason can be due to the injector values not being coded to the new DME. If you proved that all of the above are in good working condition and done, the last thing to address is your spark plug condition. Eventually, weak spark plugs can cause your engine to misfire, even enter limp mode when applying boost.
Based on the log if all above has been addressed, Fuel Low & Rail Pressure looks like it's dipping pretty low at some points while you're still accelerating which could contribute to it breaking up as you're describing. I didn't see any odd AFR's other than the normal spikes as you let off your pedal which don't indicate failing upstream/downstream O2 Sensors. However, I did see Bank 1 and/or Bank 2 approach the 15:1 mark occasionally, which is lean territory. This leads to a few reasons based on the Fuel Low-Pressure readings:
-Failing Low-Pressure Fuel Pump
-Failing EKP Module for the Low-Pressure Fuel Pump
If those have been addressed and you still break up pretty bad around the same point while having low readings Fuel Rail Pressure-wise, the next thing to be looking at is your High-Pressure Fuel Pump.
Again, this is just assuming based on experience along with no codes being mentioned. Let us know what your trouble codes are as soon as you can
allenj125
There are no active codes which surprised me. The car is doing the same thing with the msd81 as it did with the msd80 with the exception that it would fry a Mosfet or two when it would do it. I will start with the plugs and if it continues, sounds like I will want to address the low pressure fuel pump. The injector values are correct. I did check those first. I am running index 9s
Reactions: ktb_e92
allenj125
I have 2 more graphs here. I see a drop in both low pressure and high pressure fuel at higher boost. Does this look like a lpfp issue?
  • 2025-04-03 15_13_12 IJE0S v10_0 stg 1+ 93_98 - 93 100 - e30 100 - e30 100AT_xHP.csv
  • 2025-04-03 15_13_55 IJE0S v10_0 stg 1+ 93_98 - 93 100 - e30 100 - e30 100AT_xHP.csv
ktb_e92
60
29
Indiana
2007 335i MT6
Yeah, rail pressure seems to drop to a pretty unsafe level at times it shouldn't. Low pressure doesn't seem to stay consistently low unlike rail pressure. That calls for either a new HPFP being needed, or a new fuel pressure regulator and/or sensor.
allenj125
Thank you! Will a stock hpfp replacement work fine for stage 2 E30?
Jimmymfjames
Hey I’m sorta having the same issue but my car isn’t breaking up and I have a 29dc injection cutout code and plausibly low fuel pressure
Code that’s a shadow code and my live monitoring screen will not load when I start the car my data logging screen has never worked please help.
ktb_e92
60
29
Indiana
2007 335i MT6
Yeah, there's only one type of HPFP for the N54, unlike engines like the B58 where they have "upgraded" HPFP's available. I'd save yourself the headache and buy an OEM unit. Way to many bad stories out there of rebuilt / off-brand HPFP's. Plus, an OEM one will have a lifetime warranty if you order it on sites like ECS Tuning or FCP Euro.
ktb_e92
60
29
Indiana
2007 335i MT6
That could either be your LPFP dying, starving your engine of proper fuel pressure which is causing a slight misfire, or a failing injector. Otherwise you wouldn't see a cutout code pop up, let alone the LPFP plausibility code.
As far as your monitoring screen not loading, just make sure your MHD app is up-to-date and it's successfully connecting to the MHD wifi. If not, do a hard-restart on your phone and see if that helps.
