So on my current pcv setup im using a 2jz metal pcv valve which i believe is what the rb and ade valve are using just modified to fit in the valve cover, those of you using those pcv valves and some kind of external can setup pulling vac off the manifold how many hg's are you seeing in the crankcase? Maybe @Rob@RBTurbo or @AD-ENG could chime in and see. Im doing some self testing to see with that setup what my crankcase is under and its barely under any vac at all, sub 1 hg. I have the stock flapper valve in place hooked up to a breather can, and a vargas breather oil cap that i have made sure is sealing properly.
