This will be the first production engine which features a variable compression ratio. Producing 268hp, it can infinitely vary between 8.0:1 and 14.0:1 depending on the situation over a period of 1.5 seconds. Low compression when performance and higher boost is needed and a higher compression when cruising and conditions for economy are optimal.
Paired with a CVT this should be a very efficient SUV. Look for it this fall starting at $37,000
More Coverage: http://www.caranddriver.com/features/the-2018-infiniti-qx50-is-a-car-worth-waiting-for-feature
