17x11 on a 135i
Turby
144
107
Kcmo
Was able to get a 17x11 wheel with a 315/35/17 tire to fit pretty nicely in the rear, unsure on offset for now until I measure it out but I believe it's around 58. I also have the hub conversion but an 8ish mm spacer was needed so all added up I'm going to say et60. I plan on getting wider lips after doing a 1m conversion and possibly fit a 335? I'll keep updating this post.
  • Love
Reactions: tisdrew
Milan
413
241
jebi se
your mom
Not bad but you would have been better off with a 275 on a 15". The width doesn't really help straight line traction
gmagnus7
174
73
135i N54
Damn. Is it just me or does it look like he can tuck it in more with all that space between the shock? Why was the 8mm spacer needed?
Turby
144
107
Kcmo
There's space between the shock but on these cars the body of the car sticks out on the inner wheel well, it hits that before it hits the shock
Milan
413
241
jebi se
your mom
You don't need a 15 for traction, 17s will do just fine it's all in the setup
Is this your first car that makes over 500 hp? You can go wider all you want but you need more sidewall and a taller tire if you want traction in a straight line.
People are running 6 second quarter miles on 275s but I'm sure you've got it all figured out
Turby
144
107
Kcmo
I know man lol I'm not disagreeing. A 255/60 would probably hook better than a 345/30 because of the sidewall like you're saying.
For these cars though a 17 with suspension upgrades will do just fine for traction for the average power level. When I end up turning it up pass 700 again I'll probably need some 15s for a dig.
