17T Turbo Balance Conundrum
Subwoofer
267
48
What is it with you ppl sending things over to the USA just for getting a closed deck?! There are plenty of companies in the EU and I bet my arse in the UK who can do a simple job like closed deck. It is being done for decades and no wonder born in the USA.
If you don´t have competent companies around you then go to subi performance for example in Germany.
Just buy the CSS and ship it with the engine to them or contact them prior to buying the CSS and align with them about the project.
I was only suggesting it as I have looked in the UK, and yes, I have a machine shop that can do it nearby, have they done it for an N54, ever ? No.
I want someone competent in N54, and their ultra sensitive sensors.
Good suggestion about SUBI, and they are “relatively” close.
687
I understand your thinking and I would also be ultra-sensitive about this operation. But you basically need a good machine shop that understands how to do closed deck conversions. It is actually a rather easy thing in the end as you are heat shrinking the parts into the block. Block is heated and inserts are as cold as possible. Some use dry ice. The critical value is the press fit. So how much overlap you want in the end.
The machined inserts are the critical point and have to be machined pretty precisely.
Subi Performance is actually really really close to me. Like 30km. Shit tons of knowledge there.
He is also working together with Tim Schrick and they converted Turbo engines into NA engines for Nürburgring multiple hour races.
Check his Youtube channel. Sometimes he streams in English but it is not his favorite language I guess :D
He is specialized in Subaru Boxer engines but now also does BMW. Said in a pretty new video that he can do all of them now.
Reactions: Subwoofer
Subwoofer
267
48
Yeah thanks for that man.
Just want it to be perfect for when I get around to it, so then it’s not in my mind!
thanks for vids I will have a look now
Brule
393
464
335i 2007 6spd manual
It's cheaper to buy a css sleeved block shipped to Australia then buying just a block in Australia.
dreptroman
19
12
E93 335i N54
I did take my turbos for balancing and they came out to be just fine. Wasted 300 euros but wanted to make sure. The paper included is bullshit but the turbos were fine and still going strong after 1 year
Reactions: MoreBoost
b4llistic
119
90
BMW N54
