10 Second Club - N54 Edition
Status
Not open for further replies.
rev210
244
335i - 08 Coupe .
At 1:13 when the car passes the tree you see yellow lights on top light up briefly as front tire crosses pre-stage and stage beams.
The timer isn't started until the car passes these beams (after the yellow lights flash). It's a rolling start not a dig and is 100% making the time better.
As is, this is a high 11-second car, at best.
Rollout debate aside , 131mph is easy 10s. Its got lots of power. Have to respect that.
For what its worth , I think the 10 is legit. Looks to me like no rollout.
Cruizinmax
128
73
09 335i
LOL seriously?
At 1:13 clear as day you see the car roll through pre stage and stage beams. Rolling start isn't a legit quarter mile time.
That is most likely the back tires. Not the front breaking the beams.
BoostedE90
79
-10
South East Texas
E90
Stock turbo is 10.19 lol on an rwd e90 gutted to 26xx lb.
This car is full weight xi it's at least 1100 lb heavier if not more
You aren’t really helping your case..
E92 with the complete interior , full weight (3650lbs) , stock turbos , no nitrous , record is 11.1, the XI with gtx wheels ran a 10.9 from a dig, get over it.
Silent11
124
86
2007 Bmw 335i
i cant believe im only 4 tenths off of a WORLD RECORD stock turbo 335i. 21.5 psi with 1.8 60 foot. Im sure there is 24-25 psi stock turbos with meth that have gotten into the 10s.
1,923
662
The car is nice good build but why don't we get the actual owner in on this ? Idk if it's TRUE but all those accusations were pretty heavy if that is the case and that goes to credibility.
Just went 10’s yesterday with it
Can you update list with our 10 second pass please
Not even my car lmao I just made the video
People are asking you how you launched this car and were speaking to you as if this achievement was your own and you replied back in the same manner. Yet when a dispute arises around the run you admit it isn't your car yet here you are asking to be credited with the runs and put on the record book?
In my opinion this is deceptive at best as you should state it is a customer vehicle(and be proud to claim this unless your role is insignificant).
Who is the owner of this car?
Slow335is
89
Minneapolis Minnesota
www.youtube.com
Single turbo 335is
I clearly put the owners name on the post where you send the info in to be on the 10 second list owners name is first thing listed also the video clearly says not my car
Slow335is
89
www.youtube.com
Single turbo 335is
I simply am stating what happened with the car.
I deleted my last reply because the first post in this thread doesn't specify the car must be yours. So I'll take the fault here. I've updated the thread and submissions must be disclosed when the run doesn't belong to the person posting.
Coupes66
BMW 335i N54
I have looked at the video and this is a normal launch at a drag strip. Yes, the car is moving before the timing commences and that is normal. The reason is that when the staging light comes on, the front edge of the front tire has broken the beam. The timing will not start until the rear of the front tire has passed through the staging beam. That means the car has accelerated/moved the length equivalent to the distance between the front edge of the tire and the rear edge of the tire before the timing starts. The attached link will explain better to those who cannot understand.
Staging Basics for Beginners
Drag Race 101: When it comes to winning drag races, it might be surprising to know that many times, the race is over before the cars even reach the 60-foot mark on the drag strip.
www.racingjunk.com
1,923
662
It's not location of timer it's the fact that the car started moving slightly early. That was my whole gaurd beam thing. You are supposed to prestage and then roll to stage then stop. If you stop before staged and then launch you accelerated more. It's why shallow hurts rt but helps et and why bracket guys go deep and it helps reaction and hurts et little but that's within allowed limits. This seemed to have been further than normal and everyone knows the most energy wasted is launch and also is the most valuable.
Edit your link does not describe what that video shows correct ? These links are great if they describe situation but you cant say this says black and blue is brown so this is black and brown it should be blue.
ReyM6
BMW 135i, M6 v10 supercharged
Who’s in charge of posting the times? They still haven’t posted my time yet of 10.817 @132mph on my 6spd 135i
  • Wow
Eisa_q8
Kuwait
Bmw 135i
Below is a list of N54 powered vehicles in the 10's, along with any details such as videos, build links or time slips. Post your own time slips below. If the run is not yours you must state explicitly the car is not yours.​
(Scroll to the side on mobile)
#¼ ET¼ MPH⅛ ET⅛ MPH60 FTYear ChassisDriver Tuner Details
10.066136.986.461108.471.5012007Jack Nazifovski @Jack335iE90 Powerglide (Slip) (Video)
10.194138.296.6251.5442007@Silentkiller335iE92 Stock 6AT Turbos 75 Shot
10.351130.956.622104.741.5152009Jimmie Johnson135i 4L80, 8.8, full interior, Motiv 750, sealed motor (Slip)
10.353130.056.658105.961.478Samson McGinnisE92 Pure S2 FTI Stage 3 TH400
10.387130.686.663104.561.5092008Victor GE92 ADE 6766, 4L80, 8.8 (Slip)
10.664130.676.938101.771.7032007@1freakyfast335iE90 4N Performance 6266 XHP (Slip)
7
10.702135.057.003104.281.6722007@noorjE90 6MT Custom ST AGP Z2 6265 @ 28 PSI E70 (Video)(Slip)
10.721130.9207.000103.3401.6642007Dorsey JamesE90 6AT Super RB (Link)
9
10.743137.347.169109.692.0292008Vargas Shop CarE90 Sequential VTT S3 Built motor(Slip)
10
10.755131.866.961103.361.678@rev210
11
10.756131.346.955104.171.489@lgitmanE92 6MT Hexon RR550 (Slip)
12
10.763137.4707.212105.6301.9452008Terry Burger @Terry@BMSE82 6AT Motiv 750 (Slip)
1310.775128.856.954102.011.5762007@Coupes66Supr RB Evo Nizpro 6AT M3 diff w/ 3.25 (Slip)
14
10.780138.447.129109.721.879Jose Rodriguez @1slow_e36E36 (Slip)(Video)
15
10.812132.2307.096103.5001.8492010David Rooney @TurbocrippleE82 6AT VTT S2 Billet (Video, Slips)
1610.817132.587.061100.921.6412008135i@ReyM6@WedgePerformanceMMP 1k E50 @ 25 PSI
17
10.822131.9907.016104.9721.5762007Shiv PathakE92 6MT FFTEC (Video)
18
10.836132.457.149104.371.780Tony Vargas @Tony@VargasTurboTechE90 6AT GC
1910.9062136.947.2693102.621.84592008Jake Spence @suspencefulE82 135i 6MT Doc Race 6266 JB4 @28 psi (Video) (Log) (Slip)
20
10.916128.6497.119102.254@dmacpro91E82 4L80E VM 466(Slip)
2110.917133.537.185104.371.7642010@Dave @ Fuel-It!E92 xi Pure S2 w JB4 and Fuelit PI (Slip)
22
10.9258131.357.1265102.161.72422007@JazRedGTE92 6AT MMPS3 (Slip)
23
10.937132.567.222104.021.8222008Tony Baker @Trickcruiser RB EVO (Slip)
24
10.960128.717.11599.621.738@luchocampE92 PS2+ (Slip)
Tribute to the first 10 second pass on May 18th 2012 by Shiv Pathak:
7
9
10
11
12
14
15
17
18
20
22
23
24
I'm pretty sure I already know the answer, but has anyone run in the 10s with stock turbos?
hi
This is time slip for 135i 2009 doc race 6266 with xhp st3 ,meth PI /pump gas stock engine stock trans tuned by @abohatims
LaserBimmer
West Virginia
2008 335xi
I see where to post now. Sorry for posting in the wrong spot. I’ll post it again so it’s in this thread. Thank you.
Aron Berry
2008 335xi
60ft 1.6160
1/8th 6.9415 @ 102.65
10.7185 @ 132.67
Video
Status
