10 Second Club - N54 Edition
Status
Not open for further replies.
Mdraysen
9 Second Club
Nov 2, 2018
7
22
75
E90
2nd pass on the car ever. Should have let higher on the stall but she's goin 9s next time.
Coupes66
BMW 335i N54
Built motor di only, on3 manifold, 6766, 4l80, 8.8 ect ect.
Thanks for the info. That 4L80E transmission would certainly make the difference in getting great times down the strip. I looked into doing the same but over here in Australia it was going to cost close to $20,000 which is more than the car is worth so I gave it a miss. A TH400 would be cheaper and work the same on the strip but it wouldn't be much fun driving on the street.
All these years later and someone finally took Shiv's crown for E9x 6MT :laughing:
A lot of work was put into getting that car into the 10's, I was one of many who were rooting for him each time he'd go to the strip! It was the beginning of the Single Turbo era IIRC.
Reactions: SJ_1989
rev210
244
335i - 08 Coupe .
Last Wed effort at the Motorplex. Was mostly running 2.0s on the AD08s at road pressure and low/mid 11s (wheel spin city 2nd and 3rd) . So decided drop to cold 26psi, rip large line lock burnout and the hurt the stall in staging. Stage early , spin it up so the tyres turn and quickly back it off before leaving on green.(checking log it was about 2k and 5 psi). Yokos werent the same afterwards the next run was err. dangerous sideways action (I took a pic of both slips together , you can see I just couldnt get on the throttle) As a tip for others, semi comp track rubber likes heat but you may only get one extreme heat cycle, burnout wise? (Admittedly the tyres tho' good tread are 3 or more years old too) Driving home they dont feel the same, so i may have paid a high price for the time. Still got the 10. No broken axles (thanks mfactory) no broken trans(thanks Nizpro)
27300
Last Wed effort at the Motorplex. Was mostly running 2.0s on the AD08s at road pressure and low/mid 11s (wheel spin city 2nd and 3rd) . So decided drop to 26psi, rip large line lock burnout and the hurt the stall in staging. Stage early , spin it up so the tyres turn and quickly back it off before leaving on green.(checking log it was about 3k and 5-6 psi). Smashed an amazing launch and no spin in each gear. However , the Yokos werent the same afterwards the next run was err. dangerous sideways action (I took a pic of both slips together , you can see I just couldnt get on the throttle) As a tip for others, semi comp track rubber likes heat but you may only get one extreme heat cycle, burnout wise? (Admittedly the tyres tho' good tread are 3 or more years old too) Driving home they dont feel the same, so i may have paid a high price for the time. Still got the 10. No broken axles (thanks mfactory) no broken trans(thanks Nizpro)View attachment 27300
Do you have the nizpro billet internals as well as the exedy clutches? You must have one of 5 or so niz pro transmission kits that were ever made based on the info I got.
To complete your entry, if you could also provide:
Year/Chassis
Turbos/drivetrain mods
Also, please check your Account Details area of your user account(click your name/picture at the top) and you should see the 10 Sec Club custom title available to you.
rev210
244
335i - 08 Coupe .
Year/Chassis
Year/Chassis
Yes the trans is a full Nizpro built Auto , with a custom trans cooler.
2008/335i Coupe
Main gofast bits ;
Pure Stage 2 Turbos - Turbo Back custom exhaust
Nizpro Custom intercooler / TFT intake/
Motive PI / AIC6 /Fuel IT Stg 3 / Motive Flex Fuel + MHD ( Currently Justin@Twisted is helping tune it ; still in the process. Previously a Wedge E60 tune)
Quaife LSD / Mfactory forged axles / Diff Lockdown kit / Line Lock
Reactions: Twisted Tuning
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
I finally made it! Am I now the only 6MT 135i on the list?
Stock motor
Stock transmission
Stock differential
Stock axles
2008 BMW 135i 6-speed Manual
Doc Race single turbo 6266
JB4 map 7 (28psi)
MHD backend flash (Wedge)
Doc Race intake manifold w/ port injection (72lb)
Precision Raceworks stage 3+ LPFP
VRSF 7.5" race intercooler
Custom 3" exhaust
Precision Raceworks ignition coils
NGK 97506 @ 0.022"
Pump E85
2560 DA
Log: https://datazap.me/u/suspenceful/1090-1369-mph?log=0&data=1-4
Gonna work on chopping that 60ft down and improve shifts to knock it down even further.
Dragy slip from the same run:
noorj
140
104
Detroit, MI
'07 E90 335i
Noor Jariri
10.702 @ 135.05mph
1.672 60'
28psi/e70%/9deg/0.83lambda
2007 BMW 335i E90 6MT
Stock motor, trans, diff, axles (150k miles)
Custom single turbo manifold
AGP Z2 6265 Billet
BMS 7.5" China Race Intercooler
BMP 750cc Port Injection w/ AIC6
Twin Walbro 450's with BMP fittings
-6AN feed line
MHD Flex Fuel - self tuned
Turbosmart eBoost Street Boost Controller
XClutch Twin Disk Organic
Mickey Thompson ET Street R 275/45/17 on Kosei K1 wheels
build thread: https://www.spoolstreet.com/boards/threads/noorjs-custom-single-turbo-build-results.5383/
29468
29469
Status
