Ya boy need some help pls
BrazjhanN54
13
Okay so, I am trying to pass emissions. I have FBO and upgraded turbos and I usually run e50 mix daily. I set my MHD back to stock map and turned my jb4 to map 4 but every time I start the car and drive for a while I get codes like
2FA3
2F6C
2F0C
2C7B
29E0
Someone pls help a struggling 21 year old conquer this mean n54
Ok update 6/13 , I reset all codes and got my lambda o2 sensor replaced, and I have all 91 gas in my car now running stock 0 map on mhd and map 4 on jb4. You guys think I’ll be able to pass smog with this?
BrazjhanN54
13
Idk I
2FA3
2F6C
2F0C
2C7B
29E0
Idk if this matters but I was also running the DP fix for a while daily with the jb4 and mhd, I took it out a few days ago
SlowE93
1,832
Just a plane ticket away !
E93
2FA3
2F6C
2F0C
2C7B
29E0
You can't run E50 on a stock map. You will trigger fuel mixture codes. Dp fix should only be used to set readiness, not on a daily basis as that will also cause issues.
jzx_andy
156
228
Perth, Western Australia
2008 E92 335i 6MT
Put 93 in it if you're running the stock flash ("stage 0") map or jb4 map 4. If you have a lot of ethanol blend fuel in your tank right now, i'd suggest you drain the tank and put pump fuel in. Those tunes are not designed for e85 blends and should only be ran with pump fuel that has an octane rating equal to or higher than what it says inside your fuel flap.
Once you've done that, reset codes and go from there.
Since you have aftermarket turbos paired with a stock tune, the car may also throw codes when you hit boost, so I'd look at getting a custom tune sorted out asap and keep easy on the right foot for now.
BrazjhanN54
13
Will I be able to pass smog with out the custom stock tune.
