Wheels and Offsets Picture Thread
Cheezy
611
225
Toledo Ohio
Here's my e92 335xi, kw v1coilovers, 255/35/18 18x8.5 et35 with 17mm spacer. -2.5°camber. It rubbed, recommend 15mm spacer or less.
Track pic has no spacer
Reactions: Hassans
RIVERS
08 335xi
Hankook V12. The rear is fine. I would stick to 235 in front. But the 245 my be ok with slight camber. I rub on bumps over 30 to 40 mph.
Ya ill definetly go 275 for the rears as for the fronts i already rub on 235 on bumps over 30mph
How much camber you running up front?
thicccmac
SW Arizona
www.ilikeeggs.com
E92/E61
Pre-LCI E92 335i with overfenders-
On f*ckboy show car days:
Pirelli PZero
F:255/35/19x12 -60, R:295/30/19x14 -50
On 40-roll days:
Nitto NT05
R: 325/50/15x12 -32 on E39 Rotors
(on Airlift V2)
LCI E61 535xi-
Pirelli PZero
F:235/40/19x9.5 +22, R:265/35/19x10.5 +22
(F: ISC Sport Coilovers, R: Modified OEM Air ride leveling sensor)
adglogow
Rochester, NY
2007 BMW 335i
Apex PS-7 in Anthracite on stock M-Sport springs and dampers
Front 8.5" ET 35 w/ Toyo R888 245's
Rear 9.5" ET 35 w/ Toyo R888 275's (*these tires run wide for a 275!)
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Apex ARC8 18x9.5 et35, 265/35/18 Azenis RT615K. Square setup, 8mm spacer and hub extender in the front. -2.2 camber rear, -2.4 camber front. KW v3, GC camber plates, M3 front control arms.
Slight rubbing on sharp bumps only, no issues at full lock or on the track.
djslim
2010 335i N54
My 2010 E90 335i N54 OEM was:
Fronts - 225/40/18 on 18 x 7.5 - total weight 45.3 lbs
Rears - 255/35/18 on 18 x 8 - total weight
OEM 47.75 lbs
I'm now running:
Fronts:
18x8.5 VOLK ZE40
255/35/18
Yokohama ADVAN NEOVA AD08 R
Total weight 43.9 lbs
Rears:
18x9.5 VOLK ZE40
295/30/18
Total weight 46.25 lbs
DjRobbins1
I'm looking into getting new tires here soon. Probably going to go with Michelin Pilot super sports. What's the biggest tires I can run on sport suspension without rubbing? My rims are BMW style 197 "BBS"
Rim specs:
FRONT: 18x8.0 ET34
REAR: 18x8.5 ET37
Bolt Pattern: 5 x 4.72 or 5 x 120
OEM Part Number: 36 11 0 396 360
Hassans
69
15
E90 LCI 335i N54
Rim specs:
FRONT: 18x8.0 ET34
REAR: 18x8.5 ET37
I wanna say 275rears for LCI sedans in terms of tires in general without rolling, I think the coupes can go more aggressive.
But on the wheels you have I personally wouldn't go more than 265, personal preference.
I'm sure others can chime in with better and more solid info.
Byrong1017
07 BMW 335i
lol
Static 07 335i 18-22k swift springs
19x10.5 +15 19x11.5 +15
-Front tire)Hancook v12 evo2 245/35/19
-Rear tire) federal SS595 265/30R19
@bgdopeboy on insta
Hokie_335i
51
24
North Carolina
2009 E90 335i 6MT
so my car is E92 pre lci
My pictures (1st in this thread) are of a 275 Michelin tire on a pre-lci coupe with no modifications so it will fit. A 285 Michelin would have required some fender/camber work to fit. That being said, I think a 275 tire may be too much for a 8.5" wheel but you would probably be able to get away with a 265 tire.
DjRobbins1
My car i is an 07 pre Lci e92
