What should rail pressure be at startup
335i_nick
98
43
I am trying to diag a no/low rail pressure situation, cant get this car to start
When cranking I see like 80-85 psi on the LPFP, but less than 100psi at the rail. I crack open a fuel line and there's nothing coming out. I am thinking its the HPFP.
Wondering what should rail pressure show upon start up?
Tiron
23
BMW 135i
At idle I believe its around 800psi, it might take 1/2sec of cranking to actually reach that though. I've never checked it during cranking specifically. If you're cranking for very long and only seeing 100psi you've got something going on the the HPFP.
335i_nick
98
43
That's what I am thinking but HPFP was completely fine before I swapped a new engine in this car, thats why it's so "weird" to me. Also trying to rule out the regulator.
4,338
Has the car ran since the swap? Keep in mind the hpfp can fail due to electronic reasons and not just mechanical.
I had one hpfp that was 'new' and it worked for less than one mile. I swapped out multiple hpfps and ruled out any chance it was install error etc.
I don't recall the fuel pressure when cranking but it should be around what you're seeing. The car can limp at that fuel pressure so it should be able to start.
Check the cable going to the hpfp and make sure it has a pwm signal going to it.
Asbjorn
854
603
European, based in China
Z4 N54 DCT
FWIW here's a cold start log from my car
And here's a log of how the rail pressure drops to 800ish psi after half a minute or so
No lpfp pressure sensor on Z4s unfortunately.
