Barry and I started some house cleaning on the Z4 today. With 30k miles, after seeing this first-hand, I have to say I'm not at all surprised to what seems to be prevalent problems people have with #5, #6 cylinders. My car at 30k with high side BMS catch can since 23k looked pretty crappy. The low side stock PCV system (with RB PCV @ 23k) recirculates oil vapor down a sequential path, from the back of the head forward and into the intake runners. That means the intake runners get dirty most at #6, #5 and decreasing down to #1. The common reports of misfires and ring land cracks on those two cylinders seems clearly obvious to me ... and I guess I'll put a flame suit on as I suspect this is not a foregone conclusion. But even at a mere 30k miles, the turbulence caused by what I saw cannot be insignificant.
We were doing valve cover gasket, plugs, RB low-side PCV and head plug, and Tial black spring. (we used Harbor Freight stuff to blast, and this 3D printed adapter for the head, which was excellent)
Just a few photos. First is Dr. Barry Battle, "Just say ahhhhhhh".
Ok ... while the flame suit is on: IMHO there is little chance anyone is going to pay someone to do a walnut blast and have it done right, where everything is cleaned. While the blasting worked well, it consistently left lots of residue, mostly the soft stuff. The walnuts would work the film and brittle materials, but just didn't dent the rest. I used a combination of 2 cans of carb cleaner and several ounces of GM upper cylinder cleaner to scrub everything out, along with dentil picks, toothbrush, and about a half roll of blue shop paper towels sheets cut in quarters. We blasted intake runners between 3-4 times with chemical soak/scrub/cleanings in between. We spent approximately 3 hours just in the cleaning part, with both of us working. I'm not sure why anyone would choose to do the low-side external PCV setup and not tap and plug the low-side feeder holes in the head that cause this problem.
Here are thumbnails of the before/after. Both sets of photos are in order, Cylinders 1 through 6.
BEFORE: [1] [2] [3] [4] [5] [6]
AFTER: [1] [2] [3] [4] [5] [6]
