VTT Single Barrel Noise
TJ Jrackers
41
16
I've been running a VTT single barrel for a few months now and have been happy with the performance, however, recently it sounds like the bearings have been going as it has a high pitched squealing noise when the bearings are cold.
Has anyone else had a similar issue? Is there anything that can be done without sending it back to Vargas as I'm in the UK so that wouldn't be viable?
Cheers
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
High pitched squealing when cold is almost always a slipping belt. If you did not replace your idlers, and tensioner when installing the kit, we have seen this cause issues many times. Make sure your belt system is in perfect working order, including all idlers, PS pulley, and tensioner. Issues like this can always be addressed by a simple email [email protected].
Chris
