VRSF S55 Front Mount Heat Exchanger Upgrade For M3 & M4 Now Available *NEW PRODUCT*
Mike @ XPH
Nov 18, 2016
468
98
Las Vegas
VRSF Competition HD Front Mount Heat Exchanger Upgrade
for your 2015 – 2019 M2 Competition, M3 & M4 F80/F82/F87 S55
Replace your inefficient factory front mounted intercooler with the VRSF Competition HD intercooler upgrade kit to get the most performance and reliability out of your M2C, M3 & M4 with the S55 engine. We designed this kit to be one of the best performing, direct bolt on intercoolers available for your BMW with special attention to quality and performance while maintaining a reasonable price. Our intercoolers allow for higher HP gains, mainly due to their ability to keep intake temps down while preventing heat soak which is a common problem with the factory intercooler. This results in a more power and increased reliability with reduced chances of pre-detonation & knock.
The most important component of any intercooler is the core. The core cools the charged air from the turbo before it enters the engine and the OEM BMW tube and fin intercooler is designed to support low boost levels and air flow. Once boost levels and air flow are increased, the OEM unit is easily overwhelmed and can not keep up with the cooling demands of a tune running more than OEM boost levels. This results in heat soak which will result in a power loss and a higher potential for pre-detonation in the upper RPM range.
Every VRSF product includes our lifetime warranty & our “No Hassle” satisfaction guarantee which includes fitment & defects. VRSF intercoolers are hand finished and pressure tested to ensure a high quality, leak free experience.
Replaces the OEM BMW 17112284608
Features
  • High density, dual pass bar & plate core.
  • Black powder coated finish.
  • CNC machined, plug and play fittings.
  • Plug and play with no modification required.
  • Compatible with any chargepipe on the market.
  • This item fits the following BMWs:
  • 2015 – 2019 F82/F83 BMW M3 S55
  • 2015 – 2019 F82/F83 BMW M4 S55
  • 2018+ F82 BMW M2 Competition S55
Note: Fits both Left Hand Drive & Right Hand Drive Models
Asbjorn
856
605
European, based in China
Z4 N54 DCT
Would be great with some (MHD) logs of iat and coolant performance (before vs after) to support the claims and make sure it doesn't impact the radiator it covers too much.
