vanos o-ring question
Seaneezy
133
34
e90 LCI 335i
had to clean and swap my vanos solenoids to chase a code. When reinstalling I understand you should be hearing a pop sound when you insert them. I don't hear this and mine go in with linear resistance. When I pull the solenoid back out, the o-ring is not on the indented part of the solenoid. I thought maybe you need to push the top seal against the o-ring during installation but no matter what way I install these, the o-ring never pops and will never sit on the indented part. Does this matter? I am applying the o-ring on the solenoid before installation, not in the cylinder head gap, which I understand some people mistakenly do. I have aftermarket oil cooler lines that I disconnected to be able to insert them as straight as possible as well.
nyt
335
2010 335xi
The ring does not sit on the indented part. It sits against the spacer.
Reactions: Seaneezy
